nonlinear B-H curve
I am looking for an example of a very simple model:
I have a permanent magnet near a pirce of iron (non linear B-H) and need
to calculate the force on the iron.
None of the model examples cover this particular case.
thanks
DAvid
2 Replies Last Post 30 sept. 2014, 09:42 UTC−4
Posted: 1 decade ago 21 sept. 2014, 05:42 UTC−4
You can calculate the force using the in-built force functions or maxwell stress tensors inside COMSOL. Alternatively there is a speaker module inside the model libraries for acoustics speakers. You could check that too.
Viv
Hi, You can calculate the force using the in-built force functions or maxwell stress tensors inside COMSOL. Alternatively there is a speaker module inside the model libraries for acoustics speakers. You could check that too. Viv
Nirmal Paudel COMSOL Employee
Posted: 1 decade ago 30 sept. 2014, 09:42 UTC−4
Dear David,
You can use the non-linear Magnetic Materials (B-H Curve) instead of a linear Iron as done in the attached model file. The attached model file is the modification of the Permanent Magnet model from the model library:
www.comsol.com/model/the-magnetic-field-from-a-permanent-magnet-78
Best Regards,
Nirmal Paudel
COMSOL Employee
USA
Dear David, You can use the non-linear Magnetic Materials (B-H Curve) instead of a linear Iron as done in the attached model file. The attached model file is the modification of the Permanent Magnet model from the model library: http://www.comsol.com/model/the-magnetic-field-from-a-permanent-magnet-78 Best Regards, Nirmal Paudel ----------------------- COMSOL Employee USA
