Postprocessing using '>'
Hi all,
I have got a question about postprocessing when I am using '>'. For example, I want to show the von mises stress over a domain. The default expression is: fsi.mises, and I can see colour distribution over the domain. However, if I change the expression to fsi.mises>50[kPa], the legend shows 0 to 1. Could anybody tell me what does 0 to 1 mean?
Thanks for you help.
Albert
2 Replies Last Post 5 sept. 2014, 02:07 UTC−4
Posted: 1 decade ago 5 sept. 2014, 01:58 UTC−4
If you use the expression "fsi.mises>50[kPa]", then the plot will contain the result of evaluating the > operator. The result is 1 the inequality is satisfied and 0 where it isn't.
It sounds as if you maybe want to restrict the plot to the the part where the inequality is satisfied. You can do this by right-clicking on the plot in the Model Builder and adding a Filter node, where you enter your logical expression.
[QUOTE] I have got a question about postprocessing when I am using '>'. For example, I want to show the von mises stress over a domain. The default expression is: fsi.mises, and I can see colour distribution over the domain. However, if I change the expression to fsi.mises>50[kPa], the legend shows 0 to 1. Could anybody tell me what does 0 to 1 mean? [/QUOTE] If you use the expression "fsi.mises>50[kPa]", then the plot will contain the result of evaluating the > operator. The result is 1 the inequality is satisfied and 0 where it isn't. It sounds as if you maybe want to restrict the plot to the the part where the inequality is satisfied. You can do this by right-clicking on the plot in the Model Builder and adding a Filter node, where you enter your logical expression.
Posted: 1 decade ago 5 sept. 2014, 02:07 UTC−4
Hi Gunnar,
Thank you very much for your reply. I tried the filter as you recommended and it worked. Thanks again.
Albert
Hi Gunnar, Thank you very much for your reply. I tried the filter as you recommended and it worked. Thanks again. Albert
