Modeling a Gaussian beam
Hello everyone,
could somebody explain to me why in the COMSOL example "Nanorods" the equation for the incoming electric field (a z-polarized gaussian beam in 2D) reads
sqrt(w0/w(y))*exp(-(x/w(y))^2)*exp(j*k*x^2/(2*R(y)))*exp(j*(k*y-0.5 atan(y/z0)))
which is different from the usual definition of a gaussian beam (e.g. on wikipedia) by a square root ( "sqrt(w0/w(y))" instead of "w0/w(y)" and a factor in front of the "atan(y/z0)"?
In the example "Second harmonic generation of a gaussian beam" they use the same definition (but in the time domain).
Thank you for your help!
2 Replies Last Post 2 sept. 2014, 06:31 UTC−4
Posted: 1 decade ago 28 août 2014, 09:02 UTC−4
Hi Frederik,
The equation COMSOL uses is for a “2D Gaussian Beam” – one that satisfies the wave equation for a 2D geometry as described in the “Second Harmonic Generation from a Gaussian Beam” COMSOL model.
Nagi Elabbasi
Veryst Engineering
Hi Frederik, The equation COMSOL uses is for a “2D Gaussian Beam” – one that satisfies the wave equation for a 2D geometry as described in the “Second Harmonic Generation from a Gaussian Beam” COMSOL model. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 2 sept. 2014, 06:31 UTC−4
Thanks for your help! Could you point me to a (non-comsol) source for this? Somehow I wasn't able to find a derivation in 2d.
EDIT: Ah, now I see how it works :) thanks!
Thanks for your help! Could you point me to a (non-comsol) source for this? Somehow I wasn't able to find a derivation in 2d. EDIT: Ah, now I see how it works :) thanks!
