Problem in convective flow simulation
Posted 21 août 2014, 04:48 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD), Chemical Reaction Engineering, Studies & Solvers Version 4.4 4 Replies
I am now trying to solve magnetophoresis model by coupling CFD and transport of dilute chemical species modules together. I want to study the dynamical behaviour of the process and I used Time-Dependent solver in my study. However, I found that 'Nonlinear solver did not converge' when I used finer mesh in my computation. Also, I found that it is more difficult to converge when I want to do the simulation for a longer time range.
The solver does converge when I used a coarser mesh and simulate for shorter time range. Yet, solver gives different solution for each computation (or study) and I think that the solution is not reliable due to the extremely coarse meshing.
I know this is a highly non-linear model as it involves convective flow (due to buoyancy force) and transport of chemical species. Is it possible to improve the convergence of the solver in order to solve this highly non-linear model by using a finer mesh? Thank you.
Leong
Leong
4 Replies Last Post 26 août 2014, 11:02 UTC−4
