Power output magnet and coil generator
I would like to get the power output from my magnet and coil generator. I used this model:
Voltage Induced in a Coil by Moving Magnet. Model ID: 14163
Of course the ’’open’’ voltage is known. But I would also like to know the voltage when the coil is connected to a resistor, so I can check the voltage drop and power output.
Is there way to model this in Comsol? Or a different way to get the same results?
Thank you,
Tom
3 Replies Last Post 10 nov. 2014, 07:46 UTC−5
Posted: 1 decade ago 19 août 2014, 07:21 UTC−4
the Comsol-way to do this is to add a new physics: a circuit (just thick of a link to a Spice simualtor)#
The circuit contains to elements
- Voltage vs Current which is linked to the coil modelled in FEA
- the load resistor.
That's all!
Regards
Jens
Hi, the Comsol-way to do this is to add a new physics: a circuit (just thick of a link to a Spice simualtor)# The circuit contains to elements - Voltage vs Current which is linked to the coil modelled in FEA - the load resistor. That's all! Regards Jens
Posted: 1 decade ago 19 août 2014, 10:39 UTC−4
Hi Jens,
Thank you. it worked like a charm!
Tom
Hi Jens, Thank you. it worked like a charm! Tom
Posted: 1 decade ago 10 nov. 2014, 07:46 UTC−5
sir i am following the same steps given in the pdf but my induced voltage remains zero. Can u suggest me where i could be wrong?
