S-Parameter of 1-Port Network
Posted 14 août 2014, 03:34 UTC−4 RF & Microwave Engineering Version 4.3a 1 Reply
Hi at all,
I need a first advice how to define a one-port network in Comsol to simulate the reflection coefficient S11.
Consider a thin film resistor (or micro strip) on a substrate. Both ends are connected via one rf probes to measure S11 and to calculate the impedance of this micro strip. There are no other pads to measure in transmission.
I want to simulate such a setup in Comsol but I’m not sure how to define the ports. In the tutorial section I found only 2-Port networks and they use lumped ports. In the RF User guide I found: “The requirement on a lumped port is that the feed point must be similar to a transmission line feed, so its gap must be much less than the wavelength.” So in my case the lumped port isn’t the right choice.
Is it right to define the left end of the micro strip as port one and the right end as port two and then my reflection coefficient is the transmission coefficient between both ports in the simulation or is there a other way?
Thanks in advance
Thanks in advance
1 Reply Last Post 14 août 2014, 19:23 UTC−4
