DRIVE TORQUE AND THRUST/EFFICIENCY
Posted 5 août 2014, 12:44 UTC−4 Structural Mechanics 0 Replies
OUTPUT TORQUE IS PRODUCING THE THRUST THAT IS RESISTED IN THE DRIVE ITSELF AND SUPPORTED BY 4 BOLTS AND PLATE ON THE STRUCTURE. IF I WANT TO ADD ADDITIONAL BEARING OUTSIDE OF THE DRIVE I WILL CAUSE SOME OF THE OUTPUT TORQUE TO BE RESISTED OR "CATCH HERE" AND SOME THRUST FORCE BEING GENERATED, AS WELL. I WILL HAVE ALSO SOME MEDIUM TO REDUCE FRICTION IN MY BEARING FOR INSTANCE LARD. I WANT TO SIMULATE THE EFFICIENCY OF SYSTEM. IT MEANS DRIVE (WITH TORQUES AND SHAFT WITH POSSIBLE ADDING BEARINGS. IT IS APPLICATION FOR ELEVATING A GATE AND THE FORCE THAT IS TO BE REMAINED IN THE SYSTEM AN AXIAL FORCE IN THE SHAFT -ACME TREAD NEEDS TO BE SUFFICIENT TO OPERATE/ELEVATE THE GATE BUT NOT SO HIGH TO BUCKLE THE ACME TREAD. THAT IS WHY I AM THINKING OF HOW TO MODEL MY ADDITIONAL BEARING.
HAS ANYBODY USED SOME COMSOL HERE? I AM USING SAP2000 FOR ANNALYSIS AND AUTOCAD FOR DRAFTING.
Hello Dubravka Todorovic
