How to identify subdomains after geomcsg()
Hello Comsol community,
I want to identify subdomains I built with an m-file.
What I do is to build objects, e.g. block3. Then I create arrays out of these blocks. Finally I create the "fem"-geometry by using geomcsg.
Afterwards I need complicated algorithms to identify my single subdomains (e.g. I want to access the first block3 in the first array). The order of these objects has regularities but it would be easier for me, if I could define the order to know that object 5 is the fifth object in array 1.
Why do I need to know the order of objects? For example to define subdomain conditions or to calculate results for a certain object. Additionally, when I add one object to the geometry I do not know whether it is first, last or at whatever position.
Is there any possibility to define the order of these objects?
Thanks for your help!
Clemens
Example:
b1=block3(1,1,1,'base','center','pos',{'1','1','1'},'rot','0');
b1_a = geomarrayr(b1,0,2,0,1,2,1);
b2=block3(1,1,1,'base','center','pos',{'1','1','3'},'rot','0');
b2_a = geomarrayr(b2,2,0,0,2,1,1);
b3=block3(3,3,1,'base','corner','pos',{'1','1','5;},'axis',{'0','0','1'},'rot','0');
clear fem;
geom = geomcsg({geomcsg(b1_a),geomcsg(b2_a),b3});
fem.geom = geom;
fem.draw = geom;
2 Replies Last Post 14 avr. 2010, 12:03 UTC−4
Posted: 2 decades ago 14 avr. 2010, 10:27 UTC−4
The way I do it is I rotate my entire model geometry so that the subdomain I want to have as sub 1 is positioned at the lowest coordinates. It's kind of hard to explain whithout pictures, but if you create a 3D array of structures (say cubes) in the COMSOL GUI and go into subdomain settings and look at the way they're numbered, you should be able to figure it out. It's the same numbering scheme with boundaries and edges.
Hope that helps,
-Matt
The way I do it is I rotate my entire model geometry so that the subdomain I want to have as sub 1 is positioned at the lowest coordinates. It's kind of hard to explain whithout pictures, but if you create a 3D array of structures (say cubes) in the COMSOL GUI and go into subdomain settings and look at the way they're numbered, you should be able to figure it out. It's the same numbering scheme with boundaries and edges. Hope that helps, -Matt
Posted: 2 decades ago 14 avr. 2010, 12:03 UTC−4
Thank you for replying. I figured this scheme. But it does just help for a certain design. When I add an additional block3 to right in the middle of the old design I need to know how many objects are "before" it (in x- and y-direction). I was wondering whether there is a possibility to number or order all subdomains (e.g. in the order of creating).
Clemens
Thank you for replying. I figured this scheme. But it does just help for a certain design. When I add an additional block3 to right in the middle of the old design I need to know how many objects are "before" it (in x- and y-direction). I was wondering whether there is a possibility to number or order all subdomains (e.g. in the order of creating). Clemens
