Volume average over selected domains in 2D axisymmetric
I am using 2D axisymmetric setup in my model consisting of two radial geometries (concurrent) with same axis at the center. In post processing, volume average under derived values does not allow me to select different domains but rather calculates volume average for whole geomety. Can anyone please help if I need to calculate volume average for separate domains?
Harkirat
1 Reply Last Post 29 juil. 2014, 03:44 UTC−4
Posted: 1 decade ago 29 juil. 2014, 03:44 UTC−4
What you can do is add a 'selection' subnode to your solution node, and use it to select only the relevant domain. The revolution will then only revolve that domain. Since the vollume average depends on the revolution it will then only be the average of that domain.
