surface of several boundarys
Hi @ all,
is there a possibility in comsol to get the surface of selected boundarys in mm ²?
many thanks for your help,
mfg Thomas Bender
5 Replies Last Post 25 juil. 2014, 09:22 UTC−4
Posted: 1 decade ago 25 juil. 2014, 06:43 UTC−4
Why do you need COMSOL? If you know the geometry you can calculate it yourself right?
Posted: 1 decade ago 25 juil. 2014, 06:45 UTC−4
Ah, but you can of course do a surface integral and instead of integrating a quantity you can integrate '1'.
Posted: 1 decade ago 25 juil. 2014, 07:22 UTC−4
Hi Pieter,
i use a mix of geometric objects (Imports of 3D CAD files and primitives in Comsol created objects) ,which i used to combine.
To use a surface integral (of select boundaries) sounds grade. Can you give me a guide rkurze,how this could be done.
cya Thomas
Hi Pieter, i use a mix of geometric objects (Imports of 3D CAD files and primitives in Comsol created objects) ,which i used to combine. To use a surface integral (of select boundaries) sounds grade. Can you give me a guide rkurze,how this could be done. thanks for your help, cya Thomas
Posted: 1 decade ago 25 juil. 2014, 07:53 UTC−4
Alternatively, you can use the Measure button. See Reference Guide manual, version 4.4, page 371.
Alternatively, you can use the Measure button. See Reference Guide manual, version 4.4, page 371. Jeff
Posted: 1 decade ago 25 juil. 2014, 09:22 UTC−4
thank you, it worke ;)
cya Thomas
thank you, it worke ;) cya Thomas
