Erik Bornhöft
COMSOL Employee
21 juil. 2014, 11:20 UTC−4
Dear Habib,
one option is shown in the following example model:
www.comsol.de/model/tin-melting-front-6234
Another option can be to define the material parameters temperature dependent with a (continuous) jump at the melting point and then solve for convection/flow even when the material is solid in reality. In your model it could just have a very high viscosity so it is approximately solid and shows no movement. Keep in mind a volume heat source/sink to consider latent heat might be necessary.
Check also for conference paper about this topic:
www.comsol.de/papers-presentations?q=melt%20metal
Erik
Erik Bornhöft
Senior Technical Sales Engineer
COMSOL Multiphysics GmbH
Robert-Gernhardt-Platz 1
37073 Göttingen
Deutschland
Knowledge Base:
www.comsol.de/support/knowledgebase/browse/900/
COMSOL Blog:
www.comsol.de/blogs/
Dear Habib,
http://www.comsol.de/model/tin-melting-front-6234
http://www.comsol.de/papers-presentations?q=melt%20metal
Erik
Erik Bornhöft
37073 Göttingen
Deutschland
Knowledge Base:
http://www.comsol.de/support/knowledgebase/browse/900/
COMSOL Blog:
http://www.comsol.de/blogs/
21 juil. 2014, 22:24 UTC−4
Erik,
Thanks for comments. I have read the tin-melt front, but It is a little bit different with my case. I want to eliminate the elements of my geometry physically ( i.e: to show formation of the hole). It is kinda complicated but I think is doable.
H. Alavi
Erik,
H. Alavi
9 mars 2015, 09:00 UTC−4
I've been working on the same simulation as yours lately. Do you have any progress? Are you able to trace the interfaces between liquid-solid and vapor-liquid phases?
Would you please email me at ZCLOVEMIT@163.com if you have some ideas?
Cheers,
Chi Zhang
Cheers,
Chi Zhang
9 years ago
8 févr. 2016, 23:27 UTC−5
Hi Chi,
Unfortunately i have not had any progress yet. But, I am going to start working on that problem again. do you have any idea how to tackle the issue :)? I will keep you posted as soon as I get any promising results
Cheers,
Chi Zhang
S. H. Alavi
Hi Chi,
[QUOTE]
Cheers,
Chi Zhang
[/QUOTE]
S. H. Alavi
Erik Bornhöft
COMSOL Employee
9 years ago
9 févr. 2016, 03:26 UTC−5
are you aware of the papers available from the following link?
www.comsol.de/papers-presentations?q=laser,melt
There also some dealing with hole formation. I guess it is worth to investigate how they did it. The one from Mr. Bachmann won the best paper award at the COMSOL conferences in Milan 2012.
Hope that helps!
Erik
Erik Bornhöft
37073 Göttingen
Deutschland
Knowledge Base:
COMSOL Blog:
https://www.comsol.de/papers-presentations?q=laser,melt
Hope that helps!
Erik
Erik Bornhöft
37073 Göttingen
Deutschland
Knowledge Base:
COMSOL Blog:
