Error with Helmholtz Coil
Posted 11 juil. 2014, 08:46 UTC−4 Version 4.4 2 Replies
I am trying to create a model to get a magnetic field profile using COMSOL version 4.4. I use the steps which are there in the tutorial for simulation of Helmholtz coil with a few changes. The dimensions are in cm and I am trying to do it in frequency domain so that I can pass AC current. The value of current is 0.25mA and frequency is 500 Hz. I am getting the following error
Failed to find a solution for the initial parameter.
Matrix has zero on diagonal.
Can someone tell me why is it so or do I have to make some changes to make sure that I pass AC current and not DC in the coil.
I have attached the file with this email.
2 Replies Last Post 14 juil. 2014, 07:10 UTC−4
