Bidirectional coupling of "Conductive media DC" with " Heat Transfer by conduction"
I am coupling "conductive media dc" to "heat transfer with conduction" to see the effect of electrical conductivity due to thermal heating and vice versa.
In the "heat transfer with conduction" mode, I have used the resistive heating "Q_dc" as Heat source value.
My question is that, for bidirectional coupling, should I use any related value of heat transfer to the current source tab in "conductive media dc" mode. Here, I am using the anisotropic conductivity.
For seeing the heat transfer effect on anisotropic conductivity, should there be any temperature dependent formula be used or the formula is already integrated in the software and it will calculate the change of conductivity automatically.
Could you anyone please let me know the answer. If there is any ambiguity in understanding the question, please let me know.
7 Replies Last Post 17 juil. 2014, 03:29 UTC−4
Posted: 1 decade ago 7 juil. 2014, 10:20 UTC−4
Are you using conductivity 'from material' or 'user defined'? In the first case you have to check if the material property is given temperature dependent. In the later case you have to specify the temperature dependency yourself anyway.
Posted: 1 decade ago 7 juil. 2014, 10:45 UTC−4
I am using "user defined" conductivity and it is temperature dependent.
Posted: 1 decade ago 8 juil. 2014, 02:42 UTC−4
So you already have a temperature dependent expression for the temperature dependent material properties? That should be enough right? Or is there an other problem?
Posted: 1 decade ago 8 juil. 2014, 12:04 UTC−4
I have a temperature dependent expression for my material. But the problem is that, now I want to see the temperature vs conductivity graph. I mean, how the conductivity varies with increasing temperature. But I can't figure out how to get this graph. Because, ultimately, this will be my output.
Hi I have a temperature dependent expression for my material. But the problem is that, now I want to see the temperature vs conductivity graph. I mean, how the conductivity varies with increasing temperature. But I can't figure out how to get this graph. Because, ultimately, this will be my output. Thanks
Posted: 1 decade ago 9 juil. 2014, 04:06 UTC−4
Can you maybe upload your model? Maybe that will help me better understand you.
Posted: 1 decade ago 16 juil. 2014, 16:34 UTC−4
I couldn't attache the .fl file. Here, I attached the model file.
Could you please get any idea from model file. If you have any problem in understanding, please let me know.
Hi I couldn't attache the .fl file. Here, I attached the model file. Could you please get any idea from model file. If you have any problem in understanding, please let me know. Thanks
Posted: 1 decade ago 17 juil. 2014, 03:29 UTC−4
Oh sorry I do not know about FEMLAB or Matlab livelink.
