Failed to find a solution
Hi all,
I am using Heat transfer in Solids and Solid Mechanics modules to find the thermal stress of a PDMS micropump that contains a fluid reservoir, where the fluid will flow out due to heat.
I am using a stationary solver. When I tried to solve I got this error message:
"Failed to find a solution.
The relative error (1.3e+002) is greater than the relative tolerance.
Returned solution is not converged."
How can I fix that?
Marwan Nafea
2 Replies Last Post 5 oct. 2016, 17:15 UTC−4
Hello Marwan Nafea
Posted: 9 years ago 5 oct. 2016, 14:03 UTC−4
Have got these error fixed ?
Posted: 9 years ago 5 oct. 2016, 17:15 UTC−4
See the support document www.comsol.com/support/knowledgebase/964/
-DW
Hello, See the support document https://www.comsol.com/support/knowledgebase/964/ -DW
