Atanas Kumbarov
COMSOL Employee
25 juin 2014, 04:46 UTC−4
Hi Yong,
COMSOL will support this operating system when it is officially released.
Atanas Kumbarov
Hi Yong,
Atanas Kumbarov
16 oct. 2014, 19:34 UTC−4
Yosemite is out today and it is still not compatible with comsol. Please fix this.
Atanas Kumbarov
COMSOL Employee
17 oct. 2014, 04:23 UTC−4
We now have instructions and a patch for installing and running COMSOL 4.4 Update 2 on Mac OS X 10.10 Yosemite. You can find the instructions at
www.comsol.com/support/updates/comsol44p3
Note that COMSOL 5.0 works out of the box on Mac OS X 10.10 Yosemite.
Atanas Kumbarov
We now have instructions and a patch for installing and running COMSOL 4.4 Update 2 on Mac OS X 10.10 Yosemite. You can find the instructions at http://www.comsol.com/support/updates/comsol44p3
Atanas Kumbarov
17 oct. 2014, 05:06 UTC−4
Which day the COMSOL 5.0 will be released?
Atanas Kumbarov
COMSOL Employee
17 oct. 2014, 05:11 UTC−4
I don't have an exact date but it will be very soon.
Atanas Kumbarov
[QUOTE]
[/QUOTE]
Atanas Kumbarov
17 oct. 2014, 07:47 UTC−4
I need to instal the update 2 because I just installed the update yosemite. But I am using the floating license of my university (EPFL).
To download the COMSOL44_osx1010.tar.gz I need to give you my license, but I don’t have any, because I only have to be connected on the wifi of my university or in vpn to be able to use comsol.
I’m working on my master thesis, and it is very urgent. Can you give me an access to this file please.
Nathan Douet
EPFL
Nathan Douet
EPFL
17 oct. 2014, 07:50 UTC−4
Ok, I manage to solve the problem.
I also have a .dat file, sorry for the previous message.
17 oct. 2014, 08:08 UTC−4
I managed to download the update but I can manage to run the command...
When I have uncompressed the file should I replace manually the bin, doc, java and plugins files?
Reagards,
Nathan
Reagards,
Nathan
Atanas Kumbarov
COMSOL Employee
17 oct. 2014, 08:42 UTC−4
Reagards,
Nathan
What error do you get?
Atanas Kumbarov
[QUOTE]
Reagards,
Nathan
[/QUOTE]
Atanas Kumbarov
17 oct. 2014, 08:49 UTC−4
I get no error if suppress the .gz of the command tar xvzf COMSOL44_osx1010.tar.gz.
But my Comsol is still not able to launch.
It is not clear in the instruction on the webpage.
"1.After the installation is complete, download the COMSOL44_osx1010.tar.gz file and place it in the COMSOL 4.4 Update 2 installation root directory."
In the file "COMSOL44" I have to create a file named "Update 2"? And uncompress the file COMSOL44_osx1010.tar.gz. in it?
Or I simply put everything in the folder updates?
I tried both and it does not work.
May you can tell me what am I doing wrong.
Nathan
Nathan
Atanas Kumbarov
COMSOL Employee
17 oct. 2014, 08:57 UTC−4
You just download the file and place it in the folder where you have installed COMSOL. If COMSOL is installed in /Applications/COMSOL44, you place the file there and then run the command. Sometimes Safari unpacks compressed files automatically upon download - if this happened to you too, you just skip the .gz part of the command and run 'tar -xvzf COMSOL44_osx1010.tar' without the quotes.
17 oct. 2014, 09:01 UTC−4
Much clearer !
Thank you very much, it works !
Nathan
Much clearer !
Nathan
17 oct. 2014, 11:47 UTC−4
So I have downloaded the folder but I do not understand the terminal part of this. I tried to put the .tar folder in my comsol4.4 application folder by dragging and dropping and then unpack it, but after unpacking it Comsol still did open.
[QUOTE]
[/QUOTE]
17 oct. 2014, 12:11 UTC−4
Reagards,
Nathan
Atanas Kumbarov
Nathan,
Did you replace the bin,doc, java, and plugin files in the comsol 44 applications folder?
Brandon
[QUOTE]
[QUOTE]
Reagards,
Nathan
[/QUOTE]
Atanas Kumbarov
[/QUOTE]
Nathan,
Brandon
17 oct. 2014, 12:14 UTC−4
How do I navigate to the applications folder where my program is installed in terminal?
Atanas Kumbarov
COMSOL Employee
17 oct. 2014, 13:56 UTC−4
/Applications/COMSOL44, you type this command in the terminal in order to get there:
cd /Applications/COMSOL44
Atanas Kumbarov
[QUOTE]
[/QUOTE]
If COMSOL is installed in [b]/Applications/COMSOL44[/b], you type this command in the terminal in order to get there:
[i]cd /Applications/COMSOL44[/i]
Atanas Kumbarov
17 oct. 2014, 14:50 UTC−4
Thank you! This fixed everything. Now the code works.
-Brandon
-Brandon
18 oct. 2014, 13:37 UTC−4
Great. But I'm still running COMSOL 4.3b (which provides all the functionality we currently need), and we can't really afford the $$$ or time to upgrade. Does/will this tool help the rest of us still running other versions of COMSOL 4?
Instructions?
Do I have to drop back my version of the OS to keep COMSOL running on my Macs?
Instructions?
10 years ago
19 oct. 2014, 15:10 UTC−4
Hello All
i also have problem to download COMSOL44_osx1010.tar.gz , i use a server to run comsol on Bauhaus university, i dont have any license file or serial number, so how can i download that file to run it on mac os x yosemite?
Hello All
10 years ago
20 oct. 2014, 06:46 UTC−4
Hello All
Dear Rouzbeh,
COMSOL Support can help you to obtain your license number. Please resend your request to support@comsol.com or contact us via the support form at
www.comsol.com/access/
Anders
[QUOTE]
Hello All
[/QUOTE]
Dear Rouzbeh,
COMSOL Support can help you to obtain your license number. Please resend your request to support@comsol.com or contact us via the support form at http://www.comsol.com/access/
Anders
10 years ago
22 oct. 2014, 10:22 UTC−4
I'm running OSX 10.10 and I've applied COMSOL 4.4 Update 2 using the terminal commands. However, I am now receiving the following message when trying to start COMSOL:
The Comsollauncher executable launcher was unable to locate its companion launcher jar.
Any suggestions on how to fix this?
Thanks!
Edit: Nvm. Re-installing fixed the issue!
Thanks!
10 years ago
27 oct. 2014, 14:05 UTC−4
I had the same Problem.
Install Java 8 Update 25:
http://download.oracle.com/otn-pub/java/jdk/8u25-b17/jre-8u25-macosx-x64.dmg
10 years ago
Ups, think I was wrong.
After having installed Java 8U25 on another Mac I replaced folders bin, doc and plugins and got the same error message.
Then I put back the originals and again moved the new ones to the directory but this time by "uniting?" the folders (sorry, german os).
Now Comsol worked.
Now Comsol worked.
10 years ago
30 oct. 2014, 01:49 UTC−4
Could you tell me how to fix "The Comsollauncher executable launcher was unable to locate its companion launcher jar." ?
Atanas Kumbarov
COMSOL Employee
10 years ago
10 nov. 2014, 02:02 UTC−5
Please contact COMSOL Support for further questions regarding the COMSOL patch for Yosemite:
Atanas Kumbarov
[QUOTE]
[/QUOTE]
Please contact COMSOL Support for further questions regarding the COMSOL patch for Yosemite: http://www.comsol.com/support
Atanas Kumbarov
