screens
An aside, before I request for help... CFD-online.com doesn't have a COMSOL branch, or at least I couldn't find it.
I'm working on an inlet plenum to a device which has a lot of tubes. This plenum takes gas and turns it upwards into the tubes. The distribution doesn't have to be "perfect," but it does have to be relatively good (within 20% rms, ultimately) so the first approximation is to try to distribute the gas using screens.
Screens seem to work well when they have relatively low solidity. But when the solidity is higher, say 30-50%, then it's very hard to get them to converge. And I don't know how.
I have tried using smaller pieces of materials (typically angle iron with the points aimed downstream), but then the difficulty becomes meshing. Although I can get the mesher to work with smaller pieces of materials, when it's time to solve, multigrid fails to establish the coarser meshes required.
Any help on this model would be greatly appreciated.
2 Replies Last Post 16 sept. 2016, 21:06 UTC−4
Hello John Stasko
Posted: 8 years ago 16 sept. 2016, 13:08 UTC−4
You have used screen option in your case ,i have a doubt in it how you have mentioned the solidity ,how did you calculate it .If you had any theoretical notes or any website link which gives detailed explanation of screen option and how to use it ,kindly please share it
Thank you
Regards
Hi You have used screen option in your case ,i have a doubt in it how you have mentioned the solidity ,how did you calculate it .If you had any theoretical notes or any website link which gives detailed explanation of screen option and how to use it ,kindly please share it Thank you Regards
Posted: 8 years ago 16 sept. 2016, 21:06 UTC−4
Actually I was sweeping through solidities manually to determine the best design option.
I finally figured out how to get it to converge, there are a lot of solver options and techniques to learn.
The short of it is that the screens work.
Actually I was sweeping through solidities manually to determine the best design option. I finally figured out how to get it to converge, there are a lot of solver options and techniques to learn. The short of it is that the screens work.
