question about discharge current in plasma jet
hi i am a PhD student , i try to model a plasma jet at atmospheric pressure using plasma module, DC discharge , the geometry of the device is a cylinder as dielectric tube and the electrode inside it and the ground around the tube.. i do not know how to calculate the discharge current , is it required to use anothe model beside DC discharge?
1 Reply Last Post 25 janv. 2016, 02:52 UTC−5
Hello Viola Maher
Posted: 9 years ago 25 janv. 2016, 02:52 UTC−5
Is it possible to create a 1D model? Just as the argon_dbd_1D model provided by COMSOL in the application library? In this built case, the discharge current may be worked out.
