Calculate the effective thermal conductivity
Posted 16 juin 2014, 06:05 UTC−4 Heat Transfer & Phase Change, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 4.3b 3 Replies
im very new in Comsol and its my first post here, so if you need more information for saving my problem just let me know.
I want to calculate the effective thermal conductivity of a tank containing insulation materials. The tank should be heated below and I want to determine the temperature at the top and bottom. With this information, I could then calculate the effective thermal conductivity of the complete tanks.
Now i created my geometry and filled the tank first with air.
But my simulation does not work. I think its due to the physics settings. Because im not sure if i did it right. In the most posts here there is written something about the heat flux. But if i dont know how to set it up.
I've attached my Comsol-file
I hope you can help me.
Greetings
Kevin
Greetings
Kevin
3 Replies Last Post 18 juin 2014, 03:09 UTC−4
