discharge current
i am a new user, and i tried to model 2 D axisymmetric DC discharge plasma jet in plasma module., how can i defined displacement current density on r axis, i cannot plot it, and how can i plot total current discharge.
thanks
3 Replies Last Post 28 mai 2014, 07:36 UTC−4
Posted: 1 decade ago 26 mai 2014, 03:58 UTC−4
For the plotting: add to the results node a 1D-plot group node, add to that node a graph node, and when you select that node you have to select the edge of your domain that is on your r-axis, and the solution group that you want to plot, and the value that you want to plot, and then click plot. That is, if COMSOL 4.1 is not too different from 4.3 and 4.4 that I have used.
Posted: 1 decade ago 26 mai 2014, 18:16 UTC−4
hi
i already select point graph to plot and when i select displacement current density,to be plotted on y axis, , if i select ground boundary to plot displacement current density nothing plotted and if i select any other boundary error message"failed to evaluate variable, variable mode1.dc,Jdr
please help me . note i use plasma module dc discharge and i want to model plasma jet
thanks
hi i already select point graph to plot and when i select displacement current density,to be plotted on y axis, , if i select ground boundary to plot displacement current density nothing plotted and if i select any other boundary error message"failed to evaluate variable, variable mode1.dc,Jdr please help me . note i use plasma module dc discharge and i want to model plasma jet thanks
Posted: 1 decade ago 28 mai 2014, 07:36 UTC−4
Hi Viola,
Have you succesfully run your simulation first so that you actually have a solution to plot? And have you selected this solution in the plot node?
What kind of boundary conditions do you have?
Hi Viola, Have you succesfully run your simulation first so that you actually have a solution to plot? And have you selected this solution in the plot node? What kind of boundary conditions do you have?
