Polymer viscosity model about Cross-WLF eqaution
I have tried to analyze the filling pattern of polymers in injection molding process with COMSOL software.
And I tried to apply the shear viscosity of the polymer to the analysis using cross-WLF equation which usually used to express the behaviors.
However, I found out that the viscosity rapidly increased when the temperature of the polymer reached glass transition temperature.
With the increasing viscosity, the analysis was failed.
I need your help with the problem.
Please let me know how I can fix the problem without the fail message.
3 Replies Last Post 23 mai 2014, 02:49 UTC−4
Posted: 1 decade ago 21 mai 2014, 11:27 UTC−4
What do you mean by 'the analysis was failed'? What error do you get?
Posted: 1 decade ago 22 mai 2014, 22:11 UTC−4
The error message is
"The following feature has encountered a problem: Nonlinear solver did not converge.
Last time step is not converged."
I don't know how can I do ....
The error message is "The following feature has encountered a problem: Nonlinear solver did not converge. Last time step is not converged." I don't know how can I do ....
Posted: 1 decade ago 23 mai 2014, 02:49 UTC−4
Maybe you should have a look at the phase change examples (heat transfer module), or have you already used that?
