Creating a Piezoelectric Stack Actuator
Hi all,
Is there any way to build a precise model of a piezoelectric stack actuator that consists of many layers?
The thickness of ceramic and electrodes layers is about 100 micrometers. So, if the height of the actuator is 10 millimetres, then I would have to create 100 layers.
Is that correct, or there is another way to do it?
Marwan
2 Replies Last Post 18 mai 2014, 10:55 UTC−4
Posted: 1 decade ago 18 mai 2014, 09:59 UTC−4
Marwan,
you can use an array node to multiply a geometry.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Marwan, you can use an array node to multiply a geometry. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 18 mai 2014, 10:55 UTC−4
That will work. Thank you so much Mr. Edgar J. Kaiser.
