Correct syntax for creating domain selection in the JAVA Api?
Posted 17 avr. 2014, 00:39 UTC−4 Interfacing, LiveLink for MATLAB Version 4.3 0 Replies
To create a variable representing multiple boundaries to avoid redundancy the following code is given:
<code>
sel1 = model.selection.create('sel1');
sel1.set([2 3 4 5 6 7]);
sel1.name('Ti bolts');
</code>
Matlab returns the following error:
Error using busbar (line 54)
Java exception occurred:
Exception:
java.lang.IllegalArgumentException: Illegal input vector
(rethrown as com.comsol.util.exceptions.FlException)
Line 54 refers to the second line of code.
Any one knows what the issue may be with the syntax if that's the problem?
Thank you,
Kayode
Hello Kayode Nwanze
