Help Needed - Lift and Drag for a Flat Plate, Normal to Flow
Posted 7 avr. 2014, 17:15 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD) Version 4.3a, Version 4.4 8 Replies
I am following the method described in the Flow Past a Cylinder Tutorial. I am evaluating the drag force over the boundary integral of my flat plate. I then compute C_d = - 2*reacf(u)/(spf.rho*V^2*height).
Can someone tell me where I might be going wrong? I have attached my COMSOL model for your reference.
v/r
Connor
-2*reacf(u) / (spf.rho* (Re*spf.nu/chord)^2 *height) / (2*height+2*chord)
That is equivalent to the following:
(Reaction Force in U) / ( 1/2 Density * U0^2 * Height ) / (Perimeter)
The perimeter term comes from the line integral. You can see that in my second line integral which integrates the #1... It gives the perimeter back as an answer. The units now come back as unitless, as they should (I think). I also made the height a parameter and included it everywhere, instead of carrying the 0.1. the domain is now 10 chords wide and 10 heights tall.
The new value I get is 0.86, which is getting closer to where you want to be, I think. Anyone else have some thoughts?
-TCL
P.S. The updated model file is attached. But I think I am 4.4... hmmm, didn't think that one through.
Does the moving wall have the same velocity component as the free stream velocity: Re*spf.nu/ chord in the x-hat direction?
I set the wall condition for the top and bottom of the domain to 'moving' at a velocity of ( Re*spf.nu/chord ) and
added a separate no-slip condition for the flat plate's boundary.
I am still getting a different value for C_d: 6.19649
It seems that it isn't necessary to divide by the perimeter within the integral evaluation which is strange as the line integral of '1' over the surface yields the perimeter. I have attached an excel spreadsheet that shows my data thus far. The values labeled "COMSOL - C_d" were returned by the equation for C_d divided by the perimeter whereas the "COMSOL w/ Perim" values are the aforementioned values multiplied by the perimeter.
-reacf(w) [N] / ( 1/2 * spf.rho * (Re*spf.nu/Diam)^2 * (pi*Diam^2/4) ) (1)
0.37155
I'm trying to plot the lift and drag force on a rotating cylinder in a uniform stream (2D) for low Re=100. I've been successfull with calculating/plot the coefficient for the non-rotating cylinder which is well in order with literature.
For the non-rotating cylinder I've used the non-slip boundary condition on the cylinder and the expression: -reacf(v)*2/(spf.rho*U_mean^2*d) for the lift coefficient. Where d is the cylinder diameter and U_mean is the free stream velocity.
Now, when I set the boundary to "sliding wall" and set a rotation velocity the calculated lift force C_L=-reacf(v)*2/(spf.rho*U_mean^2*d)=0. Why is that? please help me asap
thanking you
susobhan
Suggested Content
- KNOWLEDGE BASE Solving time dependent models with inconsistent initial values
- FORUM lift/drag forces for FSI modeling using a fluid-shell or fluid-membrane interface
- BLOG The Magnus Effect and the FIFA World Cup™ Match Ball
- BLOG Which Turbulence Model Should I Choose for My CFD Application?
- BLOG Why Do Golf Balls Have Dimples?
