time dependent study for sinusoidal wave
Dear all,
I'm trying to simulate my module in 2D axis of COMSOL version 4.3 in joule heating physics with sinusoidal input voltage of { V0*sin(2*pi*50*t)} and for the frequency of 50 Hz it will takes 0.02 second for full wave . so i must use small time step of around 0.0001sec. . i have problem when i increase the time to more than 5 second with step of 0.0001 sec .
I need to simulate my module for time between 0 sec until 300 second with time step of 0.0001. as times: range(0,0.0001,300)s
So it needs around 3 million step to get the full result and i think it's difficult to that .
is ther are any way to get it in the transient study so i can check the time that need to arrive the steady state temperature .
best regards ,
6 Replies Last Post 22 avr. 2014, 15:38 UTC−4
Posted: 1 decade ago 3 avr. 2014, 04:35 UTC−4
It is probably much more effective to do this in a seggregated way. In a first step perform a frequency domain study to get the heat production and in second time dependent step calculate the temperature effect.
Or alternatively you can do a frequency-transient study.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
It is probably much more effective to do this in a seggregated way. In a first step perform a frequency domain study to get the heat production and in second time dependent step calculate the temperature effect. Or alternatively you can do a frequency-transient study. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 3 avr. 2014, 10:04 UTC−4
Dear Edgar,
I tried the frequency transient study and i got result .
Thanks alot
Dear Edgar, I tried the frequency transient study and i got result . Thanks alot
Posted: 1 decade ago 16 avr. 2014, 03:35 UTC−4
Dear Edgar J. Kaiser,
Thank you for helping me , i did my study in frequency-transient study because by default it works as sinusoidal pulse response .
now i need the input voltage as rectangular or triangular wave. i tried to call triangular wave from function but it didn't work ., because the frequency is already defined in the study.
Dear Edgar J. Kaiser, Thank you for helping me , i did my study in frequency-transient study because by default it works as sinusoidal pulse response . now i need the input voltage as rectangular or triangular wave. i tried to call triangular wave from function but it didn't work ., because the frequency is already defined in the study. Best regards,
Posted: 1 decade ago 16 avr. 2014, 04:32 UTC−4
Hazlee,
for any non-harmonic waveforms you have to do a time domain study.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Hazlee, for any non-harmonic waveforms you have to do a time domain study. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 22 avr. 2014, 14:19 UTC−4
Dear Edgar,
Thank you helping. for periodic triangular and rectangular wave i used them from function in definitions. then in frequency transient study i determine the frequency.
i want to ask about sinusoidal wave form in frequency transient study when i enter avalue for electric potential is it RMS value or PEAK value?
for example if i need to enter 400*sin(2*pi*f*t) in frequency transient study that Vpeak=400 ,
or i should enter Vrms=400/sqt2
regards
Hazlee
Dear Edgar, Thank you helping. for periodic triangular and rectangular wave i used them from function in definitions. then in frequency transient study i determine the frequency. i want to ask about sinusoidal wave form in frequency transient study when i enter avalue for electric potential is it RMS value or PEAK value? for example if i need to enter 400*sin(2*pi*f*t) in frequency transient study that Vpeak=400 , or i should enter Vrms=400/sqt2 regards Hazlee
Posted: 1 decade ago 22 avr. 2014, 15:38 UTC−4
Hazlee, what you set is the peak value.
Edgar J. Kaiser
www.emphys.com
Hazlee, what you set is the peak value. -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
