error when coupling reactive flow and heat transfer
Posted 2 avr. 2014, 03:19 UTC−4 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Chemical Reaction Engineering Version 5.2 5 Replies
Hello everyone,
I am a Comsol beginner and I am trying to model a turbulent reactive flow (homogeneous gasphase reaction).
I created a coupled model for the reactive flow and the heat transfer, very similar to the model "syngas combustion in a round-jet burner" in the library.
The model runs for the turbulent reactive flow (at least for some concentrations given in initial conditions and inflow) but when I try to couple it with the temperature, it first seems to converge pretty well but then gives this error:
Segregated group 4
Attempt to evaluate non-integral power of negative number.
- Function: ^
Failed to evaluate operator.
- Operator: nif
- Geometry: 1
- Boundary: 1 2 4 5 7
- Expression: nif((comp1.rspf.d_w_plus<(10/(comp1.rspf.Sc_wCO^0.33333333333333331))),nojac((comp1.rspf.d_w_plus*comp1.rspf.Sc_wCO)),(comp1.rspf.d_w_plus<sqrt(((comp1.rspf.kappav*1000)/comp1.rspf.ScT_wCO))),nojac(((15*(comp1.rspf.Sc_wCO^0.66666666666666663))-(500/(comp1.rspf.d_w_plus^2)))),nojac((((15*(comp1.rspf.Sc_wCO^0.66666666666666663))+((log(comp1.rspf.d_w_plus)*comp1.rspf.ScT_wCO)/comp1.rspf.kappav))-(((comp1.rspf.ScT_wCO*0.5)*(log(((comp1.rspf.kappav*1000)/comp1.rspf.ScT_wCO))+1))/comp1.rspf.kappav))))
Failed to evaluate variable.
- Variable: comp1.rspf.wplus_wCO
- Defined as: nif((comp1.rspf.d_w_plus<(10/(comp1.rspf.Sc_wCO^0.33333333333333331))),nojac((comp1.rspf.d_w_plus*comp1.rspf.Sc_wCO)),(comp1.rspf.d_w_plus<sqrt(((comp1.rspf.kappav*1000)/comp1.rspf.ScT_wCO))),nojac(((15*(comp1.rspf.Sc_wCO^0.66666666666666663))-(500/(comp1.rspf.d_w_plus^2)))),nojac((((15*(comp1.rspf.Sc_wCO^0.66666666666666663))+((log(comp1.rspf.d_w_plus)*comp1.rspf.ScT_wCO)/comp1.rspf.kappav))-(((comp1.rspf.ScT_wCO*0.5)*(log(((comp1.rspf.kappav*1000)/comp1.rspf.ScT_wCO))+1))/comp1.rspf.kappav))))
- Expression: d((down(comp1.rspf.rho)*comp1.rspf.beta0s^0.25*sqrt(max(comp1.k2,eps))*(comp1.rspf.wCOWall-comp1.wCO)*test(comp1.wCO)/comp1.rspf.wplus_wCO)*(dvol),{test@4})
- Feature: Stationary Solver 1 (sol7/s1)
Does anyone know what my mistake is?
BTW, it converges if I set all concentrations to zero.
Thanks for any hints!
Miriam
PS: The file is too big to upload, if it is any help I can try and cut it down.
Segregated group 4
- Function: ^
- Operator: nif
- Geometry: 1
Miriam
5 Replies Last Post 16 avr. 2017, 11:28 UTC−4
