COMSOL TOOL
hi everyone
is comsol has a tool to integrate heat flux (W/m^2) over boundary and give the local distribution of the integrated power (W) at each point on that boundry?
thanks
5 Replies Last Post 1 avr. 2010, 14:53 UTC−4
Posted: 2 decades ago 30 mars 2010, 15:04 UTC−4
Thra the "postprocessing - boundary integration" tab for a double integration, or edge integration (in 2D) for a simple integration.
Check the doc too, its worth it
Hi Thra the "postprocessing - boundary integration" tab for a double integration, or edge integration (in 2D) for a simple integration. Check the doc too, its worth it Good luck Ivar
Posted: 2 decades ago 1 avr. 2010, 01:48 UTC−4
Thanks lvar
I already did but this give the total numerical value, is there any method to plot this integration at each point?
I do appreciate your help to me and others
Amir
Thanks lvar I already did but this give the total numerical value, is there any method to plot this integration at each point? I do appreciate your help to me and others Amir
Posted: 2 decades ago 1 avr. 2010, 02:42 UTC−4
Well then I beleive you must explain a little more as I do not understand you fully:
such as : are you in 2D or 3D, are you wanting to integrate over 1D of a 2D boundary or ?
Hi Well then I beleive you must explain a little more as I do not understand you fully: such as : are you in 2D or 3D, are you wanting to integrate over 1D of a 2D boundary or ? Ivar
Posted: 2 decades ago 1 avr. 2010, 12:18 UTC−4
Hi lvar
So let me explain my case. I have 3D model as follows:
10mmx10mm heat source under a copper spreader that 40mmx40mm (100% in contact). everything is isolated except the upper face of the spreader so all the heat supplied will be taken from the upper face OK. when I give power to the heating element the heat will spread out due to area expansion on the spreader surface. After I reach the required condition , I need to plot the heat flux (W/m^2) as a function of the position (x) on the spreader surface (upper face) this can be done, but instead of the heat flux I need to plot the power(W) as function of x so I need to integrate the heat flux and get the local distribution of the power at the upper face of the spreader. boundary integration gives me a numerical value but need to plot the power vs x.
I hope I explained in good way ( I am experimental person and I just start learn simulation)
Hi lvar So let me explain my case. I have 3D model as follows: 10mmx10mm heat source under a copper spreader that 40mmx40mm (100% in contact). everything is isolated except the upper face of the spreader so all the heat supplied will be taken from the upper face OK. when I give power to the heating element the heat will spread out due to area expansion on the spreader surface. After I reach the required condition , I need to plot the heat flux (W/m^2) as a function of the position (x) on the spreader surface (upper face) this can be done, but instead of the heat flux I need to plot the power(W) as function of x so I need to integrate the heat flux and get the local distribution of the power at the upper face of the spreader. boundary integration gives me a numerical value but need to plot the power vs x. I hope I explained in good way ( I am experimental person and I just start learn simulation) Thanks
Posted: 2 decades ago 1 avr. 2010, 14:53 UTC−4
well I suspect its the Extrusion coupling variables you are looking for, but let us do a dimensional check first:
You solve to get the power density over the surface it's expressed in in [W/m^2] so if you want the total power you integrate this power density with a double "boundary integration" over dx*dy which gives you a total power in [W] (the 1/m^2 is multiplied by the two "m" units of dx and of dy).
But you say you want the power as a function of X, so what you really want is probably the integration only over "dy" and the linear power density is thus expressed in W/m along an edge, but it will be dependent on x, so if you integrate once more along dx along this edge you will end up with the same total power.
If this is the case, yes it's the extrusion integration coupling variable you should study, see "guide.pdf" p275 in the 3.5a doc
You will find examples in the application docs too
good luck
Hi well I suspect its the Extrusion coupling variables you are looking for, but let us do a dimensional check first: You solve to get the power density over the surface it's expressed in in [W/m^2] so if you want the total power you integrate this power density with a double "boundary integration" over dx*dy which gives you a total power in [W] (the 1/m^2 is multiplied by the two "m" units of dx and of dy). But you say you want the power as a function of X, so what you really want is probably the integration only over "dy" and the linear power density is thus expressed in W/m along an edge, but it will be dependent on x, so if you integrate once more along dx along this edge you will end up with the same total power. If this is the case, yes it's the extrusion integration coupling variable you should study, see "guide.pdf" p275 in the 3.5a doc You will find examples in the application docs too good luck Ivar
