Export corrected velocity field data
Viviana Palacio Betancur
My model is a simple single phase fluid flow with the laminar flow module. I need to export the corrected velocities that hold the divergence-free condition. I checked with the solution and calculated the divergence with the first derivatives: ux, vy, and wz and the divergence is not zero. In the dependent variables the corrected velocities are listed as ucx, ucy and ucz. When exporting data I list those three and the error is: 'Failed to evaluate variable: ucx'.
I also tried using spf.ucx but it fails to export the data.
Or does COMSOL guarantees divergence free solutions?
Thank you.
0 Replies Last Post 18 mars 2014, 12:36 UTC−4
Hello Viviana Palacio Betancur
