Error message after compute, modeling CFD of equipment in tunnel, advice? [CM 4.4]
Posted 13 mars 2014, 11:09 UTC−4 Computational Fluid Dynamics (CFD) Version 4.4 2 Replies
                                                    Hi, I'm a very very beginner in using COMSOL Multiphysics 4.4, I've never used it before, but I've done some tutorials from the installer.
Now I'm trying to compute this model (can be seen attached, "model.jpg"), studying about air flow flowing through this equipment in a tunnel.
But, I don't know why, I got this message error after choosing the "compute" command (the error message is also attached, "comsol_error.jpg"):
Failed to evaluate operator.
- Operator: mean
- Geometry: 1
- Boundary: 2 3 4 5 142
Mean operator requires an adjacent entity of higher dimension.
- Expression: mean(comp1.spf.C_mu)
Failed to evaluate variable.
- Variable: comp1.spf.C_mu
- Geometry: 1
- Expression: nojac(max(11.06,((((0.5*(comp1.spf.C_mu^0.25))*sqrt(max(comp1.k,0)))*down(comp1.spf.rho))/(down(comp1.spf.mu)*(down(tremetric)^0.5)))))
- Variable: comp1.spf.d_w_plus
- Defined as: nojac(max(11.06,((((0.5*(comp1.spf.C_mu^0.25))*sqrt(max(comp1.k,0)))*down(comp1.spf.rho))/(down(comp1.spf.mu)*(down(tremetric)^0.5)))))
Failed to evaluate temporary symbolic derivative variable.
- Variable: comp1.spf.ep_w@VDN$comp1.k
- Defined as: ((1/((comp1.spf.d_w_plus*comp1.spf.kappav)*nojac(down(comp1.spf.mu))))*(nojac(down(comp1.spf.rho))*(comp1.spf.C_mu*((2*max(comp1.k,0))*(comp1.k>0)))))
- Expression: d(-comp1.ep+comp1.spf.ep_w,comp1.k)
Do you have any idea on why did this happen? How to solve this problem?
I will be grateful for any help/opinion you can provide.
Cheers.
- Operator: mean
- Geometry: 1
- Geometry: 1
Cheers.
2 Replies Last Post 14 mars 2014, 04:21 UTC−4
