Trouble plotting dielectrophoretic forces as a result of particle tracing simulation
Hello all,
I am simulating the motion of particles under a dielectrophoretic force in a microfluidic channel. There are two study steps: one that calculated the E-field and fluid flow field and one that calculates the time-dependent particle trajectories, using the Particle Tracing for Fluid Flow module. My model seems to run fine, and the behavior is what I would expect. However, when trying to plot an arrow surface or arrow volume of the DEP force, I always get the same error:
Failed to evaluate variable.
- Variable: comp1.fpt.Fdpx_deff1
- Geometry: 1
- Domain: 1
- Expression: comp1.fpt.Fdpx_deff1
- Plot: arws1 (Arrow surface)
Does anyone else get this or have any insight as to what the issue is? I don't understand how it can fail to evaluate the variable if it's using it to calculate the particle trajectory...
Thanks, Alisha
3 Replies Last Post 17 juil. 2014, 23:06 UTC−4
Hello Alisha Schor
Posted: 1 decade ago 16 juil. 2014, 23:31 UTC−4
Hello Alisha
Unfortunately I have exactly the same problem you mentioned.
I use fluid flow and DC modules and I get an accurate result for electroosmotic flow, but when I use a transient study for particle tracing module, I get same error that you wrote.
I am totally confused with this problem.
Please let me know if you have found a result.
I would appreciate if any one helps me.
Thanks in advance.
Hello Alisha Unfortunately I have exactly the same problem you mentioned. I use fluid flow and DC modules and I get an accurate result for electroosmotic flow, but when I use a transient study for particle tracing module, I get same error that you wrote. I am totally confused with this problem. Please let me know if you have found a result. I would appreciate if any one helps me. Thanks in advance.
Daniel Smith COMSOL Employee
Posted: 1 decade ago 17 juil. 2014, 08:36 UTC−4
Hi, the DEP force depends on properties of the individual particles, and so it only exists at the location of the particles, not in the geometric domain itself. This is why you get an error when trying to plot the force on the domain. The only way to visualize it is to set the color expression to be a component of the DEP force in the Particle Trajectories plot. To visualize the direction of the force, you can set the Point type to Comet and the expression to the DEP force.
Dan
Hi, the DEP force depends on properties of the individual particles, and so it only exists at the location of the particles, not in the geometric domain itself. This is why you get an error when trying to plot the force on the domain. The only way to visualize it is to set the color expression to be a component of the DEP force in the Particle Trajectories plot. To visualize the direction of the force, you can set the Point type to Comet and the expression to the DEP force. Dan
Posted: 1 decade ago 17 juil. 2014, 23:06 UTC−4
Thank you dear Dan for your guide.
It worked.
Thank you dear Dan for your guide. It worked.
