Material property dependent on solution variable
I'm trying to solve a 1D flow problem with Darcy's Law. The permeability of my material is supposed to be dependent on the pressure gradient in the medium. So I would first have to create a study to solve for the pressure gradient in the medium and then use the solution from the first study as an input to the second study, which calculates Darcy's law right? How would I go about setting up a study that only solves for the pressure gradient in the medium?
Thank you!
Alexandra
1 Reply Last Post 17 oct. 2016, 11:35 UTC−4
Hello Alexandra Diem
Posted: 8 years ago 17 oct. 2016, 11:35 UTC−4
Hi Alexandra,
I have a similar problem: i wanted to do a flow simulation where the permeability is depdent on the flow front, or the pressure gradient. Do you have a solution for you problem already? I would glad to discuss with you about the topic.
Dilmurat
Hi Alexandra, I have a similar problem: i wanted to do a flow simulation where the permeability is depdent on the flow front, or the pressure gradient. Do you have a solution for you problem already? I would glad to discuss with you about the topic. Regards, Dilmurat
