2D Fluid forcing a turbine to rotate
Hi, I'm reading about a lot of people who want a tutorial on how COMSOL works, and I hope this doesn't come across as that. I'm trying to build a turbine that moves due to the force of a fluid pushing on it. I've been going over other models on the website, but they all seem to be mixers or a rotating part that moves the fluid around it. In my case, it's the reverse, that is, it's the fluid that is making the turbine rotate. My question is, what should I be doing to the "Rotating Machinery, Laminar Flow" section that would simulate the fluid pushing against the turbine and making it rotate? Thank you very much for your help!
ChrisM.
7 Replies Last Post 11 févr. 2014, 16:51 UTC−5
Posted: 1 decade ago 10 févr. 2014, 06:48 UTC−5
Hi Chris,
if you want to perform an interaction between a solid and a fluid you should use the Fluid-Structure Interaction physics.
It has the equations and features for fluid-structure interaction, solving for the displacements, fluid velocity, and fluid pressure.
Have a good work.
Marino Miccio
Chemical Engineer
marinomiccio.wix.com/home
Hi Chris, if you want to perform an interaction between a solid and a fluid you should use the Fluid-Structure Interaction physics. It has the equations and features for fluid-structure interaction, solving for the displacements, fluid velocity, and fluid pressure. Have a good work. -- Marino Miccio Chemical Engineer http://marinomiccio.wix.com/home
Posted: 1 decade ago 10 févr. 2014, 10:17 UTC−5
Mr Miccio,
Thank you very much for responding to my question. I found this example on comsol.com:
www.comsol.com/model/download/177375/models.mems.fluid_structure_interaction.pdf
In the pdf file it says, "In the Add physics tree, select Fluid Flow>Fluid-Structure Interaction (fsi)", but the Comsol version I'm using doesn't have that option. Is there another way I can generate the same results?
Thank you,
ChrisM.
Mr Miccio, Thank you very much for responding to my question. I found this example on comsol.com: http://www.comsol.com/model/download/177375/models.mems.fluid_structure_interaction.pdf In the pdf file it says, "In the Add physics tree, select Fluid Flow>Fluid-Structure Interaction (fsi)", but the Comsol version I'm using doesn't have that option. Is there another way I can generate the same results? Thank you, ChrisM.
Posted: 1 decade ago 10 févr. 2014, 10:45 UTC−5
I think that this physics is the only solution to take in account the interaction between a solid and a fluid phase. It's strange that your Comsol doesn't support it. Which version do you have?
Marino Miccio
Chemical Engineer
I think that this physics is the only solution to take in account the interaction between a solid and a fluid phase. It's strange that your Comsol doesn't support it. Which version do you have? -- Marino Miccio Chemical Engineer http://marinomiccio.wix.com/home
Posted: 1 decade ago 10 févr. 2014, 18:31 UTC−5
I'm using Multiphysics version 4.3b. I went through again just in case I missed something, but Fluid-Structure Interaction physics is not there. My version shows:
Fluid Flow
- Single-Phase Flow
- Thin-Film Flow
- Multiphase Flow
- Porous Media and Subsurface Flow
- Non-Isothermal Flow
- High Mach Number Flow
- Particle Tracing for Fluid Flow
I went through each category and looked for the Fluid-Structure Interaction option, but it wasn't there. Is this an additional Module that must be purchased?
Thanks again,
ChrisM.
I'm using Multiphysics version 4.3b. I went through again just in case I missed something, but Fluid-Structure Interaction physics is not there. My version shows: Fluid Flow - Single-Phase Flow - Thin-Film Flow - Multiphase Flow - Porous Media and Subsurface Flow - Non-Isothermal Flow - High Mach Number Flow - Particle Tracing for Fluid Flow I went through each category and looked for the Fluid-Structure Interaction option, but it wasn't there. Is this an additional Module that must be purchased? Thanks again, ChrisM.
Posted: 1 decade ago 11 févr. 2014, 08:25 UTC−5
Hello Chris,
The FSI capability is in the Structural Mechanics Module and in the MEMS Module (see www.comsol.com/products/specifications/fluid-flow/#Physics%20Interfaces%20and%20Study%20Types_55197).
You can check which modules your license includes by going to File>Licensed and Used Products (in version 4.4) or Options>Licenses (in versions 4.0-4.3b)
Hello Chris, The FSI capability is in the Structural Mechanics Module and in the MEMS Module (see http://www.comsol.com/products/specifications/fluid-flow/#Physics%20Interfaces%20and%20Study%20Types_55197). You can check which modules your license includes by going to File>Licensed and Used Products (in version 4.4) or Options>Licenses (in versions 4.0-4.3b) Best, Jeff
Posted: 1 decade ago 11 févr. 2014, 16:00 UTC−5
Hi Jeff,
Thanks for your response. I checked the license, and it looks like we don't have those two modules. It's a university license, so I think I'm stuck with what we have, unfortunately.
Thanks again for your help,
ChrisM.
Hi Jeff, Thanks for your response. I checked the license, and it looks like we don't have those two modules. It's a university license, so I think I'm stuck with what we have, unfortunately. Thanks again for your help, ChrisM.
Posted: 1 decade ago 11 févr. 2014, 16:51 UTC−5
I am working on a similar problem and am taking a different approach. From what I read you are looking for the torque that the turbine put out not the internal stresses of the turbine. I am attempting to use rotating machinery fluid flow and specifying the fluid flow rate and the rotation rate and asking for the torque of the rotating element as an output.
I would like to be able to do as described above and also solve for stress in rotor, but do not see a path to do this yet.
I am working on a similar problem and am taking a different approach. From what I read you are looking for the torque that the turbine put out not the internal stresses of the turbine. I am attempting to use rotating machinery fluid flow and specifying the fluid flow rate and the rotation rate and asking for the torque of the rotating element as an output. I would like to be able to do as described above and also solve for stress in rotor, but do not see a path to do this yet.
