Particle tracing - release from a set of points
In the particle tracing module (using 3D mathematical particle tracing) is it possible to release the particles from a set of defined (x,y,z) points or from points along a parametric curve?
I can draw the curve in the geometry but am unable to use it to generate particles. In the "Release" and "Inlet" nodes you can only select domains or boundaries and not curves or points.
So then I tried the "Release from Grid" node and I could define ranges for x, y and z but then I get every x, y and z combination rather than (x1, y1, z1), (x2, y2, z2) etc which is what I need. So then I thought to make a range just for the x coordinate and then to define the y and z coordinates (and starting velocities vx, vy and vz ) based on the x coordinate for each particle (qx?) but I cannot find how to refer to its x coordinate - maybe there is some hidden variable I could refer to - I tried to guess it's name but without success.
Any ideas?
Matthew
5 Replies Last Post 19 août 2015, 09:56 UTC−4
Hello Matthew Cox
Posted: 10 years ago 28 juil. 2015, 13:15 UTC−4
I have the same problem, did you solve your problem?
I want to import a set of points with different x,y and z coordinates.
Cheers
Sepideh
Hi, I have the same problem, did you solve your problem? I want to import a set of points with different x,y and z coordinates. Cheers Sepideh
Posted: 10 years ago 28 juil. 2015, 13:39 UTC−4
Hi Sepideh,
I was not able to figure this out with COMSOL. I switched to using SIMION for particle tracing which was much more flexible on the particle properties (scripts can be used to change particle properties during flight).
Hi Sepideh, I was not able to figure this out with COMSOL. I switched to using SIMION for particle tracing which was much more flexible on the particle properties (scripts can be used to change particle properties during flight).
Posted: 10 years ago 17 août 2015, 04:51 UTC−4
In the latest version of Comsol Particle tracing Module you can now import a set of particle starting points, directions and other properties from a file, which is very useful.
You can also define starting cords in the provided physics interface and tell it to use all combinations or selected combinations. The only thing you can't do yet is use parameters in input fields which can take a list and you have to use literal (fixed ) numbers or functions based on literal numbers.
So I'd give Comsol 8 out of 10 for this so far. If they extend it so you can use parameters in all the input fields then I'd give them 10 out of 10.
In the latest version of Comsol Particle tracing Module you can now import a set of particle starting points, directions and other properties from a file, which is very useful. You can also define starting cords in the provided physics interface and tell it to use all combinations or selected combinations. The only thing you can't do yet is use parameters in input fields which can take a list and you have to use literal (fixed ) numbers or functions based on literal numbers. So I'd give Comsol 8 out of 10 for this so far. If they extend it so you can use parameters in all the input fields then I'd give them 10 out of 10.
Daniel Smith COMSOL Employee
Posted: 10 years ago 17 août 2015, 09:34 UTC−4
Hi Matthew, the ability to use parameters for the Initial Coordinates in the Release from Grid feature will be available in the next version, V5.2. You will also be able to use parameters in the Release times edit field.
Thank you for the feedback.
Dan
Hi Matthew, the ability to use parameters for the Initial Coordinates in the Release from Grid feature will be available in the next version, V5.2. You will also be able to use parameters in the Release times edit field. Thank you for the feedback. Dan
Posted: 10 years ago 19 août 2015, 09:56 UTC−4
Sounds good - when is Comsol 5.2 expected to be released?
