Water flow in a PVC pipe to measure impact of water pressure on it
I'm the beginner of Comsol Multiphysics. I wants to pass water though a PVC pipe. I have used a straight pipe using Turbulent Flow, k-ε. In geometry there are two domain one for water, another one for PVC pipe. Inlet velocity 0.1m/s. Meshing is okay. For better realization I want to attach my .mph file. But I can't . It shows file extension error. During compute in comsol 4.3b, It shows following error info:
Failed to evaluate variable.
- Variable: material.mu
- Geometry: 1
- Domain: 2
- Variable: mod1.spf.mu
- Defined as: material.mu
- Variable: mod1.spf.kinit
- Defined as: (((100*mod1.spf.mu)/(subst(mod1.spf.rho,mod1.spf.fp1.minput_pressure,unit_atm_cf)*mod1.spf.l_mix_lim))^2)
- Expression: mod1.spf.kinit
How can I get rid of these problems?
1 Reply Last Post 16 déc. 2013, 08:27 UTC−5
Posted: 1 decade ago 16 déc. 2013, 08:27 UTC−5
Have you checked if the materials are applied to the right domains and if the Turbulent flow physics is referred only to the fluid domain?
Marino Miccio
Chemical Engineer
www.youtube.com/ScuolaTech
Hi, Have you checked if the materials are applied to the right domains and if the Turbulent flow physics is referred only to the fluid domain? -- Marino Miccio Chemical Engineer www.youtube.com/ScuolaTech
