How to calculate the normal heat flux on a boundary
Posted 12 déc. 2013, 05:59 UTC−5 Fluid & Heat, Heat Transfer & Phase Change, Results & Visualization Version 4.2a 0 Replies
In order to evaluate how to derive values in the Results section, I have followed the Heat sink tutorial included in COMSOL 4.2a and once I get the results of the simulation, I calculate the Surface Integration of the Total normal heat flux (nitf.ntflux) on surfaces 2, 3, 4 and 5. These surfaces have Thermal Insulation boundary conditions by default; hence, I expected to obtain 0 W on each surface. However, the values calculated by COMSOL are nitf.ntflux = 0.01353 W (surface 2), nitf.ntflux = -0.03251 W (surface 3), nitf.ntflux = 0.03545 W (surface 4), nitf.ntflux = 0.01363 W (surface 5) and nitf.ntflux = 0.0301 W (surfaces 2, 3, 4, and 5). In this model, there is only a heat source of 1 W on surface 8; therefore, the calculated Total normal heat flux on the isolated surfaces is higher than 3% of the supplied power.
Are these results misunderstood? Or there is something wrong with the model? Or…
Could anyone help me to understand these results?
Thank you and regards.
Hello Juan Perez
