bugs in modeling instructions for Corrosion module in comsol v 4.3b
Posted 4 déc. 2013, 09:38 UTC−5 Chemical Reaction Engineering Version 4.3b 0 Replies
I'm practicing an example about corrosion science, and I find some bugs in modeling instructions for Oil Platform. You can find it in PDF Document of Corrosion Module——Tutorial Models——Oil Platform on page 9:
Difference 1
Create the final geometry as the difference between the cylinders and the imported oil platform structure.
1 In the Model Builder window, right-click Geometry 1 and choose Boolean Operations>Difference.
2 In the Difference settings window, locate the Difference section.
3 Select the objects cyl1 and cyl2 only nder Objects to add.
4 Under Objects to subtract, click Activate Selection.
5 Use the Select Box toolbar button to select the imported platform geometry.
I cannot find "cyl1 and cyl2" ( No.3), "Activate Selection" (No.4) and "Select Box" (No.5) in COMSOL Multiphysics v 4.3b
so I fail to continue this modeling.
What shall I do next?
Thank you for your attention.
Hello Jeff Jiang
