Problem transforming the Transport and Adsorption example to cylindrical geometry
Posted 22 mars 2010, 13:41 UTC−4 1 Reply
I need to set up a model describing adsorption on the wall of a cylindrical tube. I thought the Transport and Adsorption example in Multiphysics Modeling Guide (p. 32) would be a good starting point as it has the same boundary saturation mechanism as I would like to include in my own model.
However, when entering the equation for the weak term on the boundary, the entered expression is simple replaced by a zero. I suspected problems already when trying to add the weak form problem. It could not be found under 2D axial symmetry, so I had to select 2-D geometry. Does this make sense?
As I'm not an experienced user of Comsol, I must be overlooking something fundamental.
...K. Henneberg
...K. Henneberg
1 Reply Last Post 23 mars 2010, 08:26 UTC−4
