mie scattering off gold nanoparticle in water
Posted 20 nov. 2013, 08:04 UTC−5 Version 4.4 9 Replies
I have been calculating the absorption and scattering cross section from a gold nanoparticle in air correctly using the example in the model exchange:
www.comsol.com/community/exchange/215/
However when I change the medium from air to water I am seeing extremely high scattering in the forward direction of the particle to a level which cannot be accurate. To specify the water I simply change the relative permittivity to 1.7689 (from n=1.33^2) set the permeability as 1 and keep the electrical conductivity as comsol states. Does anybody know where I may be going wrong?
Also as a side question, should the thickness of the medium affect the results as I am seeing large variations depending on what I set it as?
Thanks in advance,
Josh
When running in air I defined the plane wave as E0*exp(-j*emw.k0*x) however when replacing this with water I have to change the equation to E0*exp(-j*emw.k0*1.33*x). This includes the refractive index of water in the equation to scale the wavelength. Is this the correct thing to do?
Many thanks
Josh
I think I may have worked it out but would appreciate someone double checking that it is valid as I dont have a physics background.
Many thanks
Josh
Dear Josh,
I've met exactly the same problem as you, and I did not work it out for a long time. I've tried what you said, and it works. Actually, I also tried to replace emw.k0 with emw.k, which is the wavevector in medium (different for different domains), and it turns out that emw.k can not give the correct result. When you plot emw.Ebz, you will see that the field is not correctly scaled inside the Au sphere. Thus, multiplying emw.k0 with the refractive index of surrounding medium, e.g., water, is correct. I believe you did a correct job.
Thanks a lot for your sharing.
Cheers,
Song
Hello guys. Thank you so much for your previous posts. I was trying to do the same thing, and I followed your instructions. The resonance did show up at the right wavelength, however, the numbers for absorption and scattering cross-sections are off. I wonder do you guys have any idea what is going on? Hopefully you will have time to reply. Thanks a lot!
How are you calculating the cross sections? A good model that helped me was the Scatterer on Substrate:
www.comsol.com/model/scatterer-on-substrate-14443
Take a look at the referenced equations in that to see if they help,
Josh
Josh
Thank you very much for your kind reply Josh. I really appreciate it. I followed that model and I got great results of sphere in a homogeneous environment. However, when I try to solve it for nanorods. The numbers are off again. I don't know if you have had similar problems before. But anyways, thank you very much for your help!
Jeremy
If the sphere is giving correct results but the nanorods don't it may be due to having sharp corners in your geometry. Perhaps try rounding the corners, I found this gives much more accurate results for me.
Otherwise make sure the intop_vol and intop_surf variables as in the example model are for the correct geometry, or try reducing the mesh size.
Hope that helps,
Josh
For the polarization along the rod it would give different extinction cross section and for polarization perpendicular to the rod length it would give different extinction cross section.
Also meshing of rod effects the results effectively, because it happens with me
regards
Jalpa
Well in case of nano rod you to take care of the fact that what polarization state of light you are incident .
regards
Jalpa
Thank you very much guys for your kind replies! I really appreciate it. The sad truth is that I am still not getting an expected value after taking care of all the possible factors that I can think of. I uploaded my project file here, if anyone can bother to take a look at it. I will really appreciate that!
I modified the model from the "Scattering on the Substrate" project. So there are some unnecessary variables, But I think now my model is describing "gold nanorod in water". The electric field looks fine, the rod is showing a longitudinal resonance, but the numbers are not matching the literature.(pubs.acs.org/doi/abs/10.1021/nn7003603)
Thank you very much in advance!
Jeremy
Suggested Content
- FORUM Water electrolyzers
- FORUM Brillouin scattering
- BLOG Gold Nanorods for Medical Treatment
- KNOWLEDGE BASE Repairing the LiveLink Interface Using the COMSOL Installer
- KNOWLEDGE BASE Solving Models with Step Changes to Loads in Time
