Computing the volume and time drivation of the change of volume, ALE
Michael Rembe Certified Consultant
I using ALE in an axi-symmetrical model. For calculating the volume I use a integration coupling variable V and 2*pi*r for integration.
Now I need dV/dt (change of volume during time). I can not use d(V,t), because it gives 0 (?). What is the right formulation as integration coupling variable ?
Now I use 2*pi*r*(rt+zt), but I'm not shure. Testing the results manual gives some differences.
Are there any hints?
Michael
2 Replies Last Post 7 août 2009, 09:33 UTC−4
Posted: 2 decades ago 7 août 2009, 08:39 UTC−4
Hi Michael, you need to define a global equation:
Equation: Vol-V
Init: whatever the initial volume is
Now you can use Volt for the time derivative of the volume (or d(Vol,t)). This is also more computationally efficient than trying to do it directly with an integration coupling variable (if you couple Volt back in the model somewhere) because the Jacobian matrix will not become unnecessarily populated.
With best regards,
Daniel Smith
COMSOL
Hi Michael, you need to define a global equation: Name: Vol Equation: Vol-V Init: whatever the initial volume is Now you can use Volt for the time derivative of the volume (or d(Vol,t)). This is also more computationally efficient than trying to do it directly with an integration coupling variable (if you couple Volt back in the model somewhere) because the Jacobian matrix will not become unnecessarily populated. With best regards, Daniel Smith COMSOL
Posted: 2 decades ago 7 août 2009, 09:33 UTC−4
Hi Daniel,
this is right! Formulating this ODE gives the correct time derivation of Vol in place of V!
Thank you very much!
Best regards
Michael Rembe
Hi Daniel, this is right! Formulating this ODE gives the correct time derivation of Vol in place of V! Thank you very much! Best regards Michael Rembe
