mphglobal in magnetic field
Hi all,
I have made a Magnetic Bearing model in Comsol Multiphysics 4.2a and I saved it as M-File. I ran it in MATLAB R2011a but the mphglobal command didn't allow me to evaluate the global variables defined in COMSOL.
Below I show you the MATLAB error message:
Error in ==> experiment at 223
A=mphglobal(model,'qx');
where qx is the global variable defined in COMSOL...
Could you please tell me what is the reason of this error?
Thank you very much,
Daniele
1 Reply Last Post 17 oct. 2013, 06:45 UTC−4
Posted: 1 decade ago 17 oct. 2013, 06:45 UTC−4
If qx is indeed a global variable then the call to mphglobal should work. Can you post your model here (or send it to support)?
Lars Gregersen
Comsol Denmark
Hi If qx is indeed a global variable then the call to mphglobal should work. Can you post your model here (or send it to support)? Lars Gregersen Comsol Denmark
