Set sin function in my heat flux boundary condition
Hello Guys,
I do not know how I can set a function in my boundary condition rather than a scalar. I need to define my wall's heat flux as a function of time which is almost like a sin function. I am sure the COMSOL should be able to handle that, but I do not know how!
Thank you
Ehsan
4 Replies Last Post 11 sept. 2011, 13:57 UTC−4
Posted: 1 decade ago 18 mars 2010, 17:01 UTC−4
I would try to multiply the heat source value (amplitude) by a "*sin(2*pi*t)" factor.
But as "t" is only defined in "transient mode" you would get an error message if you switch to back to stationary, without supressing it again.
Hi I would try to multiply the heat source value (amplitude) by a "*sin(2*pi*t)" factor. But as "t" is only defined in "transient mode" you would get an error message if you switch to back to stationary, without supressing it again. Good luck Ivar
Posted: 1 decade ago 9 sept. 2011, 16:32 UTC−4
I am trying to change the external temperature as a sinusoidal function of time. The model is in transient mode, yet i still get the unit error when i simply plug in ext. temp = 280*Sin(t).
I also tried to change it from global expression, but still i get the unit mismatch error. How else can i change the external temperature as a sine function?
Appreciate any help. Thanks
I am trying to change the external temperature as a sinusoidal function of time. The model is in transient mode, yet i still get the unit error when i simply plug in ext. temp = 280*Sin(t). I also tried to change it from global expression, but still i get the unit mismatch error. How else can i change the external temperature as a sine function? Appreciate any help. Thanks
Posted: 1 decade ago 10 sept. 2011, 05:32 UTC−4
the unit mishmthc is that "t" has units [s] and the operator sin() wants unitless values:
hence you shoud either write a[m]=a0[m]*sin(2*pi*f[Hz]*t[s]) without necessarily all units if already defined
or just sin(t[1/s]) to be unitless
Hi the unit mishmthc is that "t" has units [s] and the operator sin() wants unitless values: hence you shoud either write a[m]=a0[m]*sin(2*pi*f[Hz]*t[s]) without necessarily all units if already defined or just sin(t[1/s]) to be unitless -- Good luck Ivar
Posted: 1 decade ago 11 sept. 2011, 13:57 UTC−4
Thanks. It worked.
Thanks. It worked.
