Using Functions Based on Interpolated Data
hello. i want to ask some guide how to specify material properties as nonlinear material using COMSOL 4.3a?
Fyi, my case study about zinc oxide microvaristor as field grading material on High Voltage Insulator/Cable. Actually, i want to know the procedure to create new material properties using Comsol 4.3a.
Really appreciate your guidance. tq
1 Reply Last Post 4 nov. 2013, 14:58 UTC−5
Hello Aishah Rawe
Posted: 1 decade ago 4 nov. 2013, 14:58 UTC−5
Hi Aishah,
Have you solve this problem? I am doing the same thing as well. Thank you.
Regards
[QUOTE] hello. i want to ask some guide how to specify material properties as nonlinear material using COMSOL 4.3a? Fyi, my case study about zinc oxide microvaristor as field grading material on High Voltage Insulator/Cable. Actually, i want to know the procedure to create new material properties using Comsol 4.3a. Really appreciate your guidance. tq [/QUOTE] Hi Aishah, Have you solve this problem? I am doing the same thing as well. Thank you. Regards
