ellipse mesh
I am not able to mesh the ellipse and a line on the edge of the ellipse but i am able to do the same mapped mesh parameter for a line attached to the rectangle.
suggestions plz.
find time to check the attachment file,plz
cordially
5 Replies Last Post 13 sept. 2010, 00:39 UTC−4
Posted: 2 decades ago 18 mars 2010, 08:47 UTC−4
Read carefully the doc on meshing, but I do not beleive you can easily set up a "mapped mesh" on curved surfaces
Hi Read carefully the doc on meshing, but I do not beleive you can easily set up a "mapped mesh" on curved surfaces Good luck Ivar
Posted: 2 decades ago 18 mars 2010, 09:57 UTC−4
Dear moderator,
many thanks indeed. Tomorrow i will send the screenshot of the error message i get when i keep trying for mesh parameters for the ellipse model
cordially
Dear moderator, many thanks indeed. Tomorrow i will send the screenshot of the error message i get when i keep trying for mesh parameters for the ellipse model cordially
Posted: 2 decades ago 18 mars 2010, 16:52 UTC−4
pls do, but have you tried a free tri/teth mesh ?
Hi pls do, but have you tried a free tri/teth mesh ?
Posted: 2 decades ago 6 avr. 2010, 07:59 UTC−4
Hi Mod,
am now working on the 3D - semi-ellipsoid or better called as half ellipsoid.
once done with that i will revert back regarding the meshing proces for curved structures.
thanks for your input, i will be using free mesh to start with
cordially
ranga
Hi Mod, am now working on the 3D - semi-ellipsoid or better called as half ellipsoid. once done with that i will revert back regarding the meshing proces for curved structures. thanks for your input, i will be using free mesh to start with cordially ranga
Posted: 1 decade ago 13 sept. 2010, 00:39 UTC−4
ho mod
is that possible to import ultrasound mammogram images to comsol
ultarsound & mammo images are in jpeg format and some in DICOM format
suggestions,plz
cordially
ranga
ho mod is that possible to import ultrasound mammogram images to comsol ultarsound & mammo images are in jpeg format and some in DICOM format suggestions,plz cordially ranga
