1D integration in 2D domain
I am trying to solve a mass transfer problem in a sphere (represented by a square, just as in the packed bed reactor example).
I want to continuously integrate the concentration at each time step ONLY across y-direction (radius) to calculate how much mass has diffused out and therefore the outer concentration (which is the Dirichlet boundary concentration I use). I multiply the integral by 4*pi*y^2
In definitions/model couplings the only options are either boundary integration or domain integration, which are not useful for this problem.
Any idea is appreciated...
2 Replies Last Post 19 oct. 2013, 04:59 UTC−4
Posted: 1 decade ago 1 oct. 2013, 08:11 UTC−4
Sounds like a projection coupling operator would do the trick - If I correctly understand what you want to achieve. Check out the Reference Manual, version 4.3b, page 288.
Hello, Sounds like a projection coupling operator would do the trick - If I correctly understand what you want to achieve. Check out the Reference Manual, version 4.3b, page 288. Best, Jeff
Posted: 1 decade ago 19 oct. 2013, 04:59 UTC−4
Thanks!
Thanks!
