Heat exchange during ice cube formation !
I'm trying to solve a heat exchange problem coupled to a phase change in 2D.
The model consists in a small volume of water on contact with a metal plate. I cool down the plate gradually so at some point the water freezes.
I solve the problem of phase change by introducing latent heat in porous matrix (ice and water), so the water freezing occurs at constant temperature.
However, I should also observe the release of this heat in the metal plate so a local temperature increase of this plate, and this doesn't work in my model !
Does anybody has an idea how to solve this simple problem ? Shall I introduce a heat source ?
Thanks in advance,
Jb
1 Reply Last Post 3 sept. 2013, 08:03 UTC−4
Zoran Vidakovic, COMSOL COMSOL Employee
Posted: 1 decade ago 3 sept. 2013, 08:03 UTC−4
Dear Jean Baptiste,
In COMSOL Multiphysics 4.3b, there is a "Phase Change" feature: www.ch.comsol.com/products/4.3b/#heattransfer
Some examples can be found in the Model Gallery: www.ch.comsol.com/search/?s=phase+change&subset=model_gallery
If you need further help, don't hesitate to contact COMSOL's Support: www.ch.comsol.com/support
Zoran
Dear Jean Baptiste, In COMSOL Multiphysics 4.3b, there is a "Phase Change" feature: http://www.ch.comsol.com/products/4.3b/#heattransfer Some examples can be found in the Model Gallery: http://www.ch.comsol.com/search/?s=phase+change&subset=model_gallery If you need further help, don't hesitate to contact COMSOL's Support: http://www.ch.comsol.com/support Best regards, Zoran
