Comsol Error
I have tried to "remesh deformed geometry" on a dataset in order to export the deformed geometry as stl-file but I get the following error:
=>unsupported operation for mesh of virtual composite face
face 64
I have made some simlifications with the imported CAD geometry like "ignore edges" and "ignore vertices" in the vicinity of face 64. There are no errors or warnings with the tetrahedral mesh generated on this basis. The deformed result also seems to be error-free, it shows realistic deformation.
I can't find any documentation on this error.
Has anybody an idea? Thank you in advance!
Ralf.
1 Reply Last Post 11 nov. 2014, 07:34 UTC−5
Hello Ralf Buchwald
Posted: 1 decade ago 11 nov. 2014, 07:34 UTC−5
face 64
Ralf.
hi,bro,have you solve the problem?
[QUOTE] Hi, I have tried to "remesh deformed geometry" on a dataset in order to export the deformed geometry as stl-file but I get the following error: =>unsupported operation for mesh of virtual composite face face 64 I have made some simlifications with the imported CAD geometry like "ignore edges" and "ignore vertices" in the vicinity of face 64. There are no errors or warnings with the tetrahedral mesh generated on this basis. The deformed result also seems to be error-free, it shows realistic deformation. I can't find any documentation on this error. Has anybody an idea? Thank you in advance! Best regards, Ralf. [/QUOTE] hi,bro,have you solve the problem?
