Coefficient Form PDE Coupling
Posted 18 août 2013, 18:04 UTC−4 Low-Frequency Electromagnetics, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.3 0 Replies
I am using the Coefficient Form PDE module to simulate a material under an applied voltage. I set two Dirichlet boundary conditions for my voltage on either side of the material (imagine a single rectangle with two voltages applied on either side). Now I just simply want to add the electrical circuit module and connect my "rectangle" into a simple circuit made up of a votlage source, resistor and the rectangle. When you use the electric current module you can very easily do this by setting the the boundary conditions as a terminal, but the coefficient form PDE module simply gives you the Dirichlet BC and there is no obvious way on how to make it into a terminal and be able to connect it to the circuit. Any help will be greatly appreciated. Thank you
Hello Eduardo Barrera
