Robert Koslover
Certified Consultant
18 août 2013, 22:48 UTC−4
Just follow the instructions below. I assume you are starting with a new (empty) model.
1. Open Comsol Multiphysics 3.5a and select a new 3D model in the model navigator.
2. Choose menu item "Draw," then sub-menu item "Cylinder."
3. Enter 0.025 into the "Radius" input box. (That's 25 mm).
4. Click the "OK" button.
5. Again, choose menu item "Draw," then sub-menu item "Cylinder."
6. Enter 0.012 into the "Radius" input box. (That's 12 mm).
7. Click the "OK" button.
8. Choose menu item "Draw," then sub-menu item "Create Composite Object..."
9. Select both CYL1 and CYL2. This causes "CYL1+CYL2" to appear in the "Set formula" input box. Select the "+" sign with your mouse and type a minus sign instead. Now the "Set formula" box has "CYL1-CYL2" in it. (Alternatively, you could just type "CYL1-CYL2" into that box.)
10. Click the "OK" button.
That's it. You now have a representation of a hollow cylinder, with the geometry that you requested.
19 août 2013, 09:00 UTC−4
Thank You Sir for your reply,
I successfully draw a hollow cylinder now.
My second question is, I want to draw half cut section centrally along length hollow cylinder
Whether it is possible to draw? If it is then how to draw a hollow cylinder?
Thanking you,
Vinay Patel.
Thanking you,
Vinay Patel.
Robert Koslover
19 août 2013, 09:41 UTC−4
It's the same basic idea. You need to combine your hollow cylinder with something that trims away half of it. For example, after you create the hollow cylinder (as described earlier), create a rectangular block that is positioned so that it covers half (along the length, as you say) of the hollow cylinder. Then you can either subtract the block from the hollow cylinder or compute the intersection of the block with the hollow cylinder. You can do both of those types of things with the create composite object function.
19 août 2013, 13:38 UTC−4
Dear Sir,
Thank you very much for your valuable support, suggestion and guidance.
Your faithfully,
Vinay Patel,
Dear Sir,
Your faithfully,
Vinay Patel,
