Derivative of a dependent variable
Posted 24 juil. 2013, 09:38 UTC−4 Interfacing, Mesh Version 4.3b 0 Replies
I am using the values of a dependent variable 'phi' and its derivative in Matlab. For some reason, the numbers of nodes are different between the original dependent variable and its derivative.
For example,
for the original dependent variable
phi_PDE=mpheval(model,'phi','dataset','dset1','Edim','domain','Selection','sel1');
The result is
phi_PDE =
expr: {'phi'}
d1: [11x10067 double]
p: [2x10067 double]
t: [3x19732 int32]
ve: [10067x1 int32]
unit: {'1'}
For the derivative
mag_gradPhi_PDE=mpheval(model,'sqrt(phix^2+phiy^2)','dataset','dset1','Edim',domain,'Selection','sel1');
The result is
mag_gradPhi_PDE =
expr: {'sqrt(phix^2+phiy^2)'}
d1: [11x10135 double]
p: [2x10135 double]
t: [3x19732 int32]
ve: [10135x1 int32]
unit: {'1/m'}
Could anyone tell me the reason for this?
Thank you,
Hello Onur Sevket Aslan
