Arbitrary polarization E field at oblique incidence of plane wave
Is there a way to simulation at plane wave at oblique incidence on a surface (3D)?
I want to set the polarization to a linear combination of p and s polarization wrt the incident plane (rather than TM or TE).
I've set one set of boundaries to be floquet condition to represent oblique incidence and the other orthogonal set of boundaries to be periodic. Result is qualitatively okay but not quite accurate.
Wondering if anyone has had experience with this...
2 Replies Last Post 6 juin 2011, 00:48 UTC−4
Posted: 1 decade ago 17 mars 2010, 16:26 UTC−4
Have you tried using the scattered-field formulation in the RF module? You can specify incident plane waves of arbitrary configuration there.
Posted: 1 decade ago 6 juin 2011, 00:48 UTC−4
Hi! Could you specify how to use scattering field here?
