Josh Thomas
Certified Consultant
1 juil. 2013, 16:54 UTC−4
Daniel-
2D axial symmetry is not extruded into 3D rather it is "revolved" into 3D in the azimuthal direction around the symmetry axis.
Also, what do you mean by 3D symmetry? You can define symmetry planes in 3D where the geometry/physics/results will be mirrored across the plane. Is that what you are referring to? This will result in 1/2 or 1/4 symmetry or maybe even 1/8 depending on how many symmetry planes you define. Also, you can have sector symmetry in 3D where symmetry planes are not orthogonal but still intersect along a common axis.
Josh Thomas
AltaSim Technologies
Daniel-
Josh Thomas
2 juil. 2013, 12:13 UTC−4
Josh,
Thank you for responding.
It is exactly what you are you referring to in the latter which I am trying to figure out: I'd like a 3D symmetry plane to project 1/2 symmetry for each of what you mentioned: geometry, physics, and results. How might I go about defining this plane, the 1/2-fractional symmetry, and the projection of it into the geometry, physics, and results?
Forgive my ignorance, I have only been working with COMSOL for a few weeks.
Best wishes,
Daniel
Josh,
Best wishes,
Daniel
Josh Thomas
2 juil. 2013, 12:19 UTC−4
Daniel-
Well, you need to build only half the geometry (or build the entire geometry and then delete 1/2 of it).
Then, under the Physics set-up, right-click and define a symmetry boundary condition on the 1/2 symmetry plane. This will constrain the values of any variables with a no-flux condition.
Then, if you want, when post-processing you can visualize in the full 3D model by generating a full, 3D data set that is re-mirrored back across the symmetry plane. This is done using the Mirror 3D data set found under Data sets.
Josh Thomas
Daniel-
Josh Thomas
31 oct. 2013, 14:34 UTC−4
Hi Josh,
Thanks for the helpful comments. I'm looking forward to applying some symmetry planes to my 3D model, but for the life of me I can't find where I can apply boundary conditions. It feels like I've tried right clicking everything under the sun :). What's killing me too is that I feel like I remember seeing it somewhere recently.
Can you be more specific about "under the physics setup right click and define a symmetry boundary condition"?
Dave
Hi Josh,
Dave
Josh Thomas
31 oct. 2013, 14:43 UTC−4
David-
Well, it depends on the physics and the modules that you have available, but if you right-click on the main physics node in the Model Builder window in most cases there is a "Symmetry" option available. For example, if you are modeling Solid Mechanics then you would right click on the Solid Mechanics node and add the Symmetry boundary condition.
Josh Thomas
David-
Josh Thomas
9 years ago
10 nov. 2015, 15:00 UTC−5
Hello Josh,
I have a different physics but similar question.
You've mentioned that under the Physics set up there is a possibility for "Symmetry" boundaries. However, it does not exist for "Electrostatics (es)", "Coefficient Form PDE (c)", and "Laplace equation (lpeq)".
My system consists of a few metallic surfaces and some dielectric structures and I'm solving Laplace equation for the surrounding area using Dirichlet Boundary conditions on the metallic surfaces. Therefore use the above-mentioned physics. In this case, what would be a way around this issue?
Best Regards,
Ari
Hello Josh,
Best Regards,
Ari
8 years ago
26 août 2017, 14:14 UTC−4
Hey have you got any clue to do it? Please let me know if you had, I am too facing same problem
7 years ago
16 nov. 2017, 05:33 UTC−5
Updated:
7 years ago
16 nov. 2017, 05:34 UTC−5
Dear COMSOL User,
I am facing simillar problem, When I go to symmtery under the physics tab, the domain is unable to select the object. I don't know why? domain option and all other options are off thats why unable to select the layer of my object whose symmetry I want to make.
If anyone could give me any idea. I am working on solid mechanics, eigenfrequency module.
Thank you
Dear COMSOL User,
Thank you
